-   Chrysler Voyager & Town & Country (https://www.chryslerforum.com/forum/chrysler-voyager-town-country-21/)
-   -   2006 Grand Voyager front wheel grinding noise (https://www.chryslerforum.com/forum/chrysler-voyager-town-country-21/2006-grand-voyager-front-wheel-grinding-noise-12003/)
blackice Jul 29, 2010 05:52 AM
I recently had new discs and pads fitted on the front wheels. A short while afterwards, we noticed a "rubbing" sound which was assumed to be the pads bedding in. This noise has got worse, and is more a rotational grinding noise now, especially when coasting and is louder when turning RH corners. The noise lessens when turning left, when accelerating and is not noticeable during braking actions. My local garage has checked the brakes and the hub bearings which I'm told are ok.
What else should be checked? Is it the drive shaft?????
blackice Jul 29, 2010 05:57 AM
Oh and it's a 2.8CRD if that helps.
gareth111278 Jul 29, 2010 11:02 AM
You say you've had it checked but have they checked for correct location of the brake pads?
I once did my pads & got one pad incorrectly located , it was fouling on the center part of the disc. My wife was away with it & the breakdown service came out but he couldn't find the fault, she brought it back & I found it.
Worth a look?
Gareth
Merlin Jul 29, 2010 12:32 PM
Get it checked again. Could be cheep parts but not likely to be drive shaft. I have had ABS sensors contacting the drive shaft due to corrosion build up but sounds more like some one has done something wrong.
blackice Aug 5, 2010 01:46 PM
Success!!!
:D Guys
Thanks for the hints - took car to the garage and had them review the brakes. They removed front pads, calipers etc and found hard build up of brake dust - they removed this, cleaned and reassembled the brakes. Also for good measure unclipped CV rubber boots, regreased and resealed. All for < £50.
All is working well now with no noise!!!!
Thanks very much. :)
blackice Aug 5, 2010 01:50 PM
Thanks it worked
