2006 Town & Country 6 Cyl. 3.8 L - Instructions how to replace radiator ?
I've got a 2006 Town & Country 6 Cyl. 3.8 L need to replace radiator; can anyone share any information, weblink, youtube videos, pdf. file, etc.. explaining the process of replacement ? It has a crack on it and leaking really bad. I googled it but found crappy weblinks with barely any good information on it...
Thanks chamuko1967 |
GAS ENGINES
Fig. 1 - A/C Condenser – 2.4L/3.3L/3.8L Engines 1 - A/C CONDENSER 2 - AUTO TRANS COOLER TAPPING BLOCK 3 - UPPER CONDENSER MOUNTING BRACKET (2) 4 - RADIATOR 5 - LOWER CONDENSER MOUNTING BRACKET (2) 1. Disconnect negative cable from battery. 2. Remove radiator upper crossmember support. (Refer to 23 - Body/Exterior/CROSSMEMBER, Radiator - Removal) . WARNING: Do not remove the cylinder block plug or the radiator draincock with the system hot and under pressure because serious burns from coolant can occur. 3. Drain the cooling system. (Refer to 07 - Cooling - Standard Procedure) 4. Remove the radiator fans. (Refer to 07 - Cooling/Engine/FAN, Cooling - Removal) 5. Disconnect coolant reserve/recovery hose. 6. Remove vapor purge solenoid from mounting bracket. 7. Disconnect upper and lower hoses from the radiator. 8. Lift the A/C condenser straight up to disengage the lower A/C condenser mounting brackets from the radiator. Separate the condenser from the radiator by lifting upward to disengage from lower mounts. Allow the condenser to rest in front of radiator. 9. Radiator can now be lifted free from engine compartment. Care should be taken not to damage radiator cooling fins or water tubes during removal. |
(Post 36826)
GAS ENGINES
Fig. 1 - A/C Condenser – 2.4L/3.3L/3.8L Engines 1 - A/C CONDENSER 2 - AUTO TRANS COOLER TAPPING BLOCK 3 - UPPER CONDENSER MOUNTING BRACKET (2) 4 - RADIATOR 5 - LOWER CONDENSER MOUNTING BRACKET (2) 1. Disconnect negative cable from battery. 2. Remove radiator upper crossmember support. (Refer to 23 - Body/Exterior/CROSSMEMBER, Radiator - Removal) . WARNING: Do not remove the cylinder block plug or the radiator draincock with the system hot and under pressure because serious burns from coolant can occur. 3. Drain the cooling system. (Refer to 07 - Cooling - Standard Procedure) 4. Remove the radiator fans. (Refer to 07 - Cooling/Engine/FAN, Cooling - Removal) 5. Disconnect coolant reserve/recovery hose. 6. Remove vapor purge solenoid from mounting bracket. 7. Disconnect upper and lower hoses from the radiator. 8. Lift the A/C condenser straight up to disengage the lower A/C condenser mounting brackets from the radiator. Separate the condenser from the radiator by lifting upward to disengage from lower mounts. Allow the condenser to rest in front of radiator. 9. Radiator can now be lifted free from engine compartment. Care should be taken not to damage radiator cooling fins or water tubes during removal. Thanks !! chamuko1967 |
dont worry about hot to drain the coolant it will come out when u remove the hoses
everything else is self explanatory |
