2007 chrysler voyager radio
Old Jan 6, 2019 | 07:28 PM
Stefano Minney's Avatar
Default 2007 chrysler voyager radio
Good evening,sorry for my bad english but i am from italy. I would like to ask someone about audio sistem on my car. I got all infos about sistem infinity wich has a different canbus sistem. I checked everything but now i am going to bypass signal pre in into original amplifier; i checked what the radio send and this is definitely and high power signal. Someone of you knows how many watts?ohm? Thanks so much
Old Jan 7, 2019 | 05:30 AM
This thread might be helpful Aftermarket Radio
Old Jan 7, 2019 | 12:04 PM
Default Answer:
hello Alan thanks for interest,but my question was a bit diffetent; i like to keep the original radio but i've also checked the radio send a high level signa to the amplifier, is this the reason why i got i can bypass radio concerning source, but i can use it to manage with fad bal and everything else/ so question was what' s that main high level output power in watts and wich impedence. thanks again
Old Jan 7, 2019 | 12:24 PM
I think you will find that information attached to the amplifier, though I'm pretty sure the impedance is 2 Ohms.
Old Jan 7, 2019 | 04:05 PM
oh about it yeah it must be; no infos on the amplifier, first time i tried to connect straight to my new ampli i got a terrible result, second time i did it thru high low circuit it worked but with any chance to trim volume, so i tried straight to connect that main output from the radio to a speaker and i realized it's pretty strong i think around 20watts; i' ve found in my basement an alpine 30X2 or 35x2 2ohm amplifier with gain control; i will try to trim it rightly and see how it works as main input source.i wish to solve it.Thanks for your help and support
Old Jan 8, 2019 | 11:01 AM
Stefano, have a read through this post, I'm sure you will find some very useful information in it.
corvairbob
May 21, 2018 12:44 AM
never2hot
Aug 14, 2016 08:04 PM
pregis100
Mar 11, 2014 03:46 AM
JZ00
Feb 1, 2010 08:02 PM
quattj
Dec 23, 2006 10:31 PM
