2008 T&C Break problems
Hi
The breaks on my 2008 T&C does not releasy fully and the discs get really hot. I've noticed that it is the same on all four wheels. I've removed the pads and made sure that they can move freely in the caliper, so the problem is most likely not related to the pads getting stuck in the caliper. I also noticed at some occations when I pressed the brake pedal just a bit and rather soft, that when I released the pedal the breaks continued to break for a second or so. Does anyone have any ideas on what may be causing my problems? Thanx Thomas |
Assuming there is no air in the system, it sounds like a faulty master cylinder.
If there was air in the system, I think I would see more effects of that, and I have seen no such indiations, the breaks works fine otherwise.
