2008 T&C MyGig display screen messed up with lines & dots
Sometimes the MyGig display screen gets messed up with lines and dots all over it, like the display
is going bad. I believe this happens when the key-fob is not pushed all the way into the ignition or it is tilted a bit in the ignition. There is some kind of interference. Once you push the key-fob all the way inside the ignition and straighten it out the MyGig display screen corrects itself and goes back to normal. Hopefully Chrysler will have a recall on this and fix the ignition slot to hold the key-fob better. Don't forget, Chrysler, we typically have 2 - 6 other keys dangling on the other end of our key-fob which add up to a couple of ounces of counter weight!! Thanks and see you out there, Loki Sunrider |
