2010 chrysler town and country cooling fan
I have a 2010 chrysler town and country 3.8 the cooling fan was replaced and seems to run alot more often Im wondering if anyone knows witch way air is suppose to go mine is blowing out the front from engine compartment I have always seen on other cars air comes from outside into engine compartment Im wondering if this unit was wired backwards or not.Thanks Ken
Originally Posted by Charlie Marie
(Post 110927)
Sorry This is the cooling fan for radiator
(Post 110929)
Did someone wire in a new connector to the fan? Sure sounds like the polarity was reversed on the 2 wire connector IF that was the case. You are correct that it should draw air from outside into the engine bay thru the grill.
I called 2 Chrysler garages got 2 different answers of witch way flow should be and no the pug was never cut the fan was wired wrong I just switched direction and seems to be working fine now but thanks for your help just in case anyone else installs a new fan it it suppose to take from outside into engine compartment just like I thought but when I called first Chrysler garage and they told me outward so it had me baffled for a while.
