2010 T&C Windshield Wiper Sprayer Issue
The windshield wiper sprayer will not work. Neither the front or back sprayers have fluid coming out of them. I can hear the pump when I command the sprayers on. I have disconnected the hose to the spray nozzles and have no fluid coming from them when commanded on. The washer fluid tank is full and does not seem to be emptying when I actuate the sprayers.
Since the pump seem to be working or doing something, I am not sure where to go? Any suggestions? |
Disconnect the line at the pump. If it doesn't squirt change the pump. The impeller could be spinning on the shaft. If it squirts then you may have a pinched or plugged line. Any maintenance done lately?
