'97 3.3V6 juddering and knocking
Just hit the 101K miles mark, and the car is starting to seriously judder, especially around 1.5-2K revs.
I think it's just the plugs, as they've never been changed. However, going up hill a bit, there is a loud knocking noise comming from the front middle. Sounds like the engine mounts, but you can't feel anything when it knocks. Any ideas? Thanks guys! |
It can be the lockup. I had that in my grand Voyager 3,8 V6 automatic trans from time to time, aspesually in uphill in low rev, just like you said. I solve the problem with goingfrom D to 3 (no overdrive) on those hills, but I knoew it's a common problem with overdrive, it gets hot....
Try changing tranny oil. The oil shall be red, nor orange or light brown. And chenge filter as well... I don't know about changing trusters in the tranny... anyone done that? |
Hi thanks for that.
I don't think it's an OD lockup as it does it in all gears and now does it at idle. There is however a serious knocking noise, deffinetly metallic happening, apparently worse in the morning. It is deffinetly metallic, and it also knocks with the revs, but up hill it's a really bad knock and you can feel it through the pedals. |
did u spin a bearing or something? rocker needs adjusting?
I don't think so. The metalic knocking I've discovered is something to do with the aux. belt.
There is a firework noise comming from the exhaust manifold we think. Seems like unburnt fuel is igniting in there. MPG is very poor as well. |
if the knocking is coming from the accesory then make sure all the brackets are tight
as for the MPG issue: try seafoam (an engine detergent and treatment fluid) for more info on that do some research online. but anyway u should probably dump a 1/2 can of seafoam in your gas tank and this will make the whole fuel system squeaky clean as well as clean some carbon out of the engine cylinders |
