Is 97 voyager 3.3 ECU plug n play?
Old Jul 15, 2011 | 11:39 AM
goco's Avatar
Default Is 97 voyager 3.3 ECU plug n play?
Hi can anyone tell me if you can just replace the ECU with one from another vehicle for a 97 UK Grand Voyager 3.3LE ??
or does it need main dealership intervention ?
Cheers
Old Jul 15, 2011 | 12:43 PM
u are asking for trouble if u just install something to your van that came out of another van and if u do the dealer cant just reprogram it to your van it does not work that way.
Old Jul 16, 2011 | 01:31 AM
goco's Avatar
Hi Chrysler tech, so what are my options then if my ECU is blown ? I was having some top end work done by a local garage (not dealership) which meant disturbing the engine wiring harness. The car started ok after the work, but next day wouldn't start - after investigation they say the wires in the harness were cracked and dry and had shorted out due to being moved, and this short has blown the ECU.
Does this mean my 14 year old is a scrapper now ??
Cheers
Old Jul 16, 2011 | 12:14 PM
there are places u can get rebuilt PCM with everything already programed
Old Jul 17, 2011 | 07:55 AM
goco's Avatar
Ok - thanks for the info. I have found a couple of places in the uk i can get mine remanufactured.
But does the picture change any if my ignition key is not a CHIPPED one ?? (black key and fob) - Could I then replace with an ecu with the same partnos and have no problems ? (I expect the answer to be NO! so don't hoold back!).
Cheers
emhomes
Jan 19, 2014 05:42 AM
Markmysite
May 12, 2010 07:13 AM
Duan
Apr 26, 2008 09:38 PM
PDQ Hemi
Dec 29, 2006 02:07 PM
