99 TnC Ltd. Where's that clogged drain?
Wifes Van is dripping water all over the inside of the Van and none is dripping out on the street.
I cant find the drain hose. I would appreciate the benefit of somebody's experience. Where is it? Where's that hose accessed from? Up top or down below? What's it next to? If the location is complex, take a photo for me. Thanks a million. Dick |
RE: 99 TnC Ltd. Where's that clogged drain?
passanger side ,outside stick your hand down behind the power steering pump and its a rubber tube facing down on the firewall right behind the belt.
:)ChryslerTech, you win the 'good deed for today' prize.
I'll bet a gallon came out when I poked that drain with a wire. What causes that to happen? This is the second time in three months.I Is something going wrong with the Van? |
:)ChryslerTech, you get the 'Good deed for today' award. Thanks a bunch for that info.
I'll bet a gallon came out when I poked a stiff wire into that hole. Whats causing the Blockage? Is something going wrong with the van? That's the second time in three months. Is this bad news? |
do u park under a tree or have alot of trees in the area stuff getsdown the cowl and will eventuly get inside the hvac housing and stay there. DO u smell a musk sent when frst start the ac?
Hmmm good questions:eek:
She keeps it in an open shed. We may have had Oak leaves, Bird droppings and Bugs. I dont ever remember having that ugly smell in the Van. Maybe I can take the cowl off, or fashion some kind of small tube for the end of the Shop Vac to sneak down in there and fish around for lost children and other small rodents. Thanks for the tip. |
welcome
| All times are GMT -5. The time now is 06:46 AM. |
