| United1 |
Aug 11, 2009 08:51 AM |
Chances are you have mold/mildew on your evaporator or your drain is partially clogged. When the AC is turned on, do you see a puddle on the ground? If not, clean out the evap drain, which pokes thru the firewall. If you do have a puddle, than I would say you have a mold/mildew issue. A band aid that I have heard that works for a while is to turn on the AC (outside air, not recirc) on high and spray Lysol into the cowl. The Lysol will get sucked in and help with the mold and mildew. Have not tried it myself, but others have reported some success. Not permanent success, but for a few months. Other option is to remove the dash to clean out the evap, but I am guessing that you don't want to do that.
