ABS light on !!
Guys (n' Gals !!),
I have a problem in that the ABS light on my 2005 2.5 CRD Voyager is permanently on. It was an intermittent problem but now it is on all of the time. Is this likely to be a faulty sensor or the sensor ring that has cracked ? Any ideas please ? Regards zepsdad :confused: |
abs light
ive had two supposedly fixed under warranty in the last three months, but it comes on if i go thru a deep puddle so dont know if theyre broken again or if its just dirt, but it stays on a while then goes out ..
Is the horn working?
Huh ??
At the risk of leaving myself open to ridicule Zycho, yes the horn does work. lol....any ideas ?
zepsdad |
Happened to us last year and comes on intermittently just now after all the bad weather.
I put it on ramps and pressure washed all around the back of the wheels last year, it put it off. Still to try this year. |
Had same problem. Bought new sensor for a front brake... Then took it for a shop to change it, all they did was cleaned everything and now works like it should be (3 months no problem). So now have a useless ABS sensor, if someone wants to buy it...
