Aftermarket radio/DVD install
Hi all, vehicle is Grand Voyager LX UK spec.
OK here goes, have looked at aftermarket install and the no sound issue. Problem I have is no relay for NBS, but still have grey yellow signal wire to amplifier ? Now according to Crutchfield it requires a relay installed in between HU and Amp. How do I know this is the infinity as there is no indication, but it is showing the same problem as it would with the infinity. Any help appreciated Thanks |
So are you installing an after market Head unit to the stock amp did I understand you correctly
Yes trying to install an aftermarket head unit. Have found out its the Boston audio with a J1850 data protocol.
Thanks for your reply |
