Aftermarket stereo no sound G. Voyager 05
Hello
Have spent all day with no avail to get sound on 2005 Grand Voyager (UK). I assume there is an amp somewhere stopping it.There was no stereo in when bought the car. Fitted iso convertor, sound is coming out of the head unit. Checked the relay box there is no NBS relay fitted. Checked behind 4 speakers and there are no amps. Any ideas please? |
Amp is behind the right rear panel.
thank you will try looking in morning
tried looking in drivers rear panel nothing inside.
there must be one somewhere anybody any ideas please? |
it is there look more forwards, you have to remove the seat belt.
thank you will have another look tomorrow.
Have been told need to put acc+ on green/grey wire to bypass ems and power up amp. Do you know if this is correct please? |
Sorry I don't know that side of it.
My 05 USA version says the amp is in the fender pocket behind the right rear speaker. It actally says to remove the amp through the speaker hole.
Many thanks for your replies will try this when next day off.
Hi Guys,
I do have the same problem. I did find the AMP after taking off the speaker on the driver side at the back (I have a Voyager 2004/2005). The AMP has the following number on it: 05091006AE. Not quite sure what to do though. Also not quite sure how to remove the amplifier itself should there be a need to remove it. Will google the serial number to see if I get anything. Thanks, Mathias |
