airbag light and error code P0016
Hello, I have a 2006 Chrysler GV 3.3 petrol that has just had the flexplate replaced. I also replaced the cam and crank sensors and in attempting to start after the repair I found I had low fuel pressure so I replaced the fuel pump as well. . First start after the repair the car started perfectly and ran great. However as soon as the car warmed up I had the engine light come on with the error code P0016 again. Next the airbag light came on and so I checked all the yellow connectors I could find under the seats & below the ashtray/centre console. Cleaned all the ABS ring gear and sensors but still no joy. Can anyone tell me if there is any correlation between the airbag light and P0016?
cheers |
Further to my post.
My scanner wont read SRS codes so I took it to a parts shop who have that type of scanner and they did not get a current code for the airbag, However they got P0016 and when they tried to clear the code it cleared P0016 but then from Engine management up came a message saying it couldn't clear the SRS from the system memory. The operator could not explain that to me but what I am thinking is that I have a problem with the engine management block where all the relays and fuses are located. Now I am in past my pay grade!
Does anyone have any suggestions? |
I'm pleased to say cleaning the connectors again has got rid of the SRS light.
It's the cam/crank (P0016) sensors that has got me beat. I have replaced the flexplate that was cracked as well as both sensors The check engine light only pops up when the engine reaches normal operating temp. I can run the car up to 5000 RMP without a problem when its warming up thru all the gears and up to highway speed. I have not heard of any connection between the operating temperature and P0016 Does anyone have any suggestions ? |
