Airbag light stays on
Old Mar 13, 2009 | 08:24 PM
02Voyager's Avatar
Default Airbag light stays on
2002 Chrysler Voyager. Was told it is the passenger squib open/active, no stored codes. 72,250 miles.
It has something to do with the passenger seat wiring/sensor maybe? Horn works so I don't think it's the clockspring.
Anyone got a clue?
Old Mar 13, 2009 | 09:26 PM
pass squib is the pass side airbag assembly not seat
r and r dash to replace the air bag itself.
now if U mean pass seat belt pre tensioner then yes that's a seat belt buckle assembly.
Old Mar 14, 2009 | 02:01 PM
ghlkal's Avatar
The airbag light is on (system isn't operative), right?
Could be a connector issue as the system needs to "sense" the correct amount of current in the wires. On my GMs, I've had to unplug and replug the connector to ensure it's snug in order to turn off the "SRS Airbag" light.
Old Mar 14, 2009 | 06:16 PM
Merlin's Avatar
Hi
Just because the light is on doesn't mean the system is inoperative, it maybe only partly disabled will depend on the fault.
Old Mar 14, 2009 | 08:33 PM
02Voyager's Avatar
I'm going to try disconnecting the battery(to drain the capacitor), remove the seats, unplug and replug connectors...would dielectric grease be a bad idea for the connectors?
Anyone happen to know where all the airbag connectors are? I saw the one's under the seats and read about 1 behind the glove box. I'm gonna trace the wires from the seats and make sure there are no breaks while I'm in there.
Thanks for the help btw
Old Mar 15, 2009 | 09:50 PM
dont waste your time the squib is the firing pins for the air bag not a connector issue.
there has to be a certain resistance that the squibs want to see and if they are out of range then u get that code.
Old Mar 16, 2009 | 09:09 AM
02Voyager's Avatar
If the clockspring failed would I get that code?
Old Mar 16, 2009 | 03:03 PM
Merlin's Avatar
Hi
If the clockspring failed you would get drivers squib circuit.
Old Mar 16, 2009 | 07:00 PM
U said u got a code with the pass side squib open
Old Mar 16, 2009 | 08:46 PM
02Voyager's Avatar
I have a paper from the previous owner that has that written on it.
The exact words are "Pass squib open...Active...No stored codes"
