Antifreeze leak.
Hi to all, Im new here and I dont speak/write well in English, so pardon me my mistakes please.
I have a T&C 2009 and yesterday I smelled antifreeze and noticed some steam under the hood, I checked the engine compartment and found antifreeze over the drivers side of the engine over the battery try, and most parts there, I took out the plastic cover and saw the foam of it with a lot of antifreeze and pulls of antifreeze in the upper part of the engine, I didnt see any spray or leak at idle. The reservoir was almost empty. Can you help me? where is the thermostat located?, where is the water pump located? Why is the antifreeze where I found it? Thanks in advance. BTW I dont know if here is the rigth place to post mi questions |
well here is the prob we face being online no one is next to u looking at this stuff so no one call inform u of what is leaking.
@ CHRYSLER TECH: did you read my email?
yep and there is nothing I can do for u
(Post 63630)
Why is on the top of the engine and in the drivers side the leak? (the pulleys and belt its in the passenger side) where is the water pump? where is the thermostat? Do you have any diagram with the route of the hoses? Thanks again. I hope somebody else will chime in here soon. |
buy a service manual it will have pictures of what U are asking for
(Post 63647)
Update: I found the leak, it its from a plastic "Y" that one rubber hose goes from the firewall to the "Y"; other rubber hose goes to a metal pipe that seems to go to the radiator and de front single part of the "Y" the short rubber hose goes to the left side of the engine. Im going to order that piece from the dealer, but my question now is:
The rubber hoses that atach to the "Y" has a special clamps, like wide rings or cilinders, with two holes in each opposite side, how can I take them out? Do I need a special tool to rotate them?, or the new "Y" come with the hoses and those clamps? Thanks in advance. |
Originally Posted by RÖENTGEEP
(Post 63806)
The rubber hoses that atach to the "Y" has a special clamps, like wide rings or cilinders, with two holes in each opposite side, how can I take them out? Do I need a special tool to rotate them?, or the new "Y" come with the hoses and those clamps? Thanks in advance. Please help me. Thank you. |
