-   Chrysler Voyager & Town & Country (https://www.chryslerforum.com/forum/chrysler-voyager-town-country-21/)
-   -   Any ideas??? (https://www.chryslerforum.com/forum/chrysler-voyager-town-country-21/any-ideas-24064/)
royal100805 Mar 12, 2015 01:01 PM
Any ideas???
Does anybody know whether the fuel lift pump and sender unit from a 2.5 crd will fit into a 2.8 crd? Chrysler weren't too helpful today. If anyone could help that would be great as I have located a couple of cheap working units at a local scrappy.
Regards
Dan
goggs Mar 12, 2015 03:57 PM
2.5crd faults on here about air getting in fuel filter at rear axle and causing engine shut downs so can't imagine there's a pump in the tank otherwise fuel would be leaking out at the filter.
tfb Mar 13, 2015 02:49 AM
don't think there is room in front of the tank for the assembly, but not certain
Regards
Richard
royal100805 Mar 13, 2015 07:33 AM
The one I have seen is describing it as being integrated with the fuel level sender unit? When i compared the two they both look exactly the same. I can try and post a link if it helps.
goggs Mar 13, 2015 02:57 PM
Must be a 2.8 crd then.
goggs Mar 13, 2015 03:55 PM
3 Attachment(s)
Here's the info on a 2004 2.5crd...Do petrol and diesel use same level sender and pump or is picture just a reference.
royal100805 Mar 14, 2015 01:45 AM
Goggs that is perfect. Well I think I am going to order the one I have seen. It's only £30 and they both look identical. The only issue being that the wiring loom on my 2.8 may not have the capability of powering the pump so I might have to run a couple of wires to a 12v feed somewhere. As long as the unit fits it shouldn't be a hard job. I have had the tank off before and I have access to a ramp. I shall keep you updated if it is a success or not.
Cheers
Dan
goggs Mar 14, 2015 03:09 PM
Update...Yes..
