auto Transmission issue
Hi all,
Maybe someone has any experience or similar problem.
I have a 2007 voyager 2.8crd with auto transmission.
It is intermittent and mostly occurs on cold running.
On the second gear shift it hesitates a fraction of a second and then jumps in to gear. Mostly it happens after going down a curb or over speed bumps.
It doesn't do it on any other gear changes and on down shift. It very rarely does it when the engine is hot. I changed the oil and filter. The symptoms disppearedfor a couple of days and than it came back.
Weird or what!
Does a transmission fluid change needs to be reset in the software?
Thanks guys
Weird or what!
Thanks guys
I guess it's a RG model ?
You don't need to reset TCM when changing ATF oil , but if you leave battery disconnected the TCM will start new learn program depending how you drive.
Are you sure there is enough oil in trany ? drive a few miles and leave the car idle on level ground (in park) and check level . Chryslers is very sensitive to fluid level in trany not to much and to little will also kill it.
