Bad picture OEM backup camera
I have Grand Voyager from 2009 when reversing the picture is really fuzzy, i wonder if its the camera or the radio.
Look through the lens of the camera for any signs of condensation.
yep saw it, ordered a new one partnumber is 05026338 in case anyone wonders.
Hi All
Hope I am in the right place. I have a couple of issues with my 2013 300C 1. My Reversing Camera shows in reverse. Normally when reversing the gutter shows on the left side (In Australia) on the screen. Now it is on the right side the image has flipped horizontally 2. The other issue is my easy access has stopped working Normally when exiting the car after the motor is turned off the steering wheel goes up and the seat goes back. Does this have a fuse Thanks if someone can help |
Although this isn't the 300C forum, the 2 problems you described are common to most cars. If your battery has gone flat or been disconnected, you will need to re-programme the seat memory to your desired positions and change the camera settings in the head unit.
Originally Posted by AlanC
(Post 122743)
Sorry if I am in the wrong area. I am new to this forum. Just wanted to know where to access the camera settings in the head unit. Do you think I should re-post the messing in another area? Thanks again |
Originally Posted by allanofbrunswick
(Post 122748)
Thank you
You are very helpful |
