Blower motor resistor location 2002 T&C?
Hi!
Looking for the location and how to get at the blower motor resistor to replace it. Do I go in through the glove compartment, from the inside? Thanks! -otis |
RE: Blower motor resistor location 2002 T&C?
yes drop down the glove box and its right there
Great - easy enough. Although the part they sold me works, it's different than what I pulled. The one I pulled has four coils in a cage surrounding the resistor while the one I put in was simply a resistor with an almost ceramic flat green section.
We don't have auto-temp (I don't think). Maybe the old one was just used universally between auto and non-auto temp? Thanks for your help! |
the one U got is the new design u might haft to trim the little green nubs off a little inorder for it to fin it the slot.
But it is right. The auto temp would cost U like 100 bucks and have fins on it. |
its an updated part which calls for you to modify the opening.use a file you should be ok.moe
