Brake fluid change 2005 2.8 CRD Auto
Hi
Just a quick (and probably dumb!) question. I want to change the brake fluid, can I do this the "old fashioned"/conventional way? Ie. Suck out the old fluid from the resovoir, refill with new and then bleed each caliper by pumping the brake pedal untill clean fluid emerges (plastic tube on nipple into a jar). I heard that some brake systems must be done by vacuum onto the caliper or the servo gets messed up? Regards |
