Cant find this code??? 1996 T&C
P1768... What is that?? Help, we;re stuck in limp home mode!!:confused: Also, we ran diagnostics while driving.. It said we were going 88 when we were going 55.??
P1768-relay
output always off |
Not a lot to go on, but the P1768 relay always off, indicates the TCM relay not responding. There are some other posts about ground wire problems (Are all the shift indicators lighting up too?) so first port of call is check all the connectors and cabling to the TCM itself for any potential damage, water damage, heat damage, etc.
Transmission output sensor? Is there a diagram for the harness I can see?
