changing sway bushings...help wanted
Hello,
I will change the stabilizer ba bushing this weeken. If someone has done this before, hints will be very welcome. Regards Rafael |
RE: changing sway bushings...help wanted
no hints are needed tools and just doing it. total of 8 bolts for both things
The bushing has a slot. Can I force it to open so the sway can pass thru it, or I have to remove the sway from the end and make the bushing to go over to its position?
Regards Rafael |
I did the bushings yesterday. Half an hour and all the noises are gone.
A very more detailed indication how to do the job can be found in the following link http://forum.chryslerminivan.net/sho...highlight=sway REGARDS Rafael |
