Check engine light error code Grand Voyager 2004
I get 10 flashes from check engine light. When turning ignitionkey 3 times.
Anyone know what the errorcode is? Tom |
Do you not get code numbers on the key dance, like P0235, etc..
key dance?
What motor is in your van and what country market area are you from?(USA,UK,etc.) The "key dance" is to turn the ignition key from the off position to the run(not crank) position 3 times, on the third time leave it in the run position. Code(s) in a P_ _ _ _ format will show up in place of odometer reading. When finished it will display the word dONE. Record these codes as they appear and post them here, so we can try and help.
thanks, That was much easier then the advice i got first :)
errorcode: p0032 O2 Sensor. any tips on quickfix or do i need to get it replaced? |
So how about responding with answers to questions posed to you so we here can understand what you already know is happening with your vehicle.
