Clutch/Fork Worn Symptons???
Both seem to look ok, do you have an image of a new one. Or shall i order one one to see the actual difference, price is horrendous from main dealer. Vin is -54Y124612, Can you let me know when you have a moment, box is back out of the car now. Also price and if you can supply me with them. Thanks
Hi
sorry don't have one in stock so can't show you an image. Part numbers I gave you are correct now I have checked with your vin number. Place to look is on the fork were the bearing clips on it will be very thin.
It's a hard choice to make I guess do you replace the clutch again and see if it fixes it or replace the fork and pivot. If it was me I would replace the fork and pivot if the fork looks thinning were the bearing clips on.
Merlin Thanks for the help on this, the pivot was ok, although the fork did look quite worn, hence not allowing the clutch to disengage. Fork has been at an engineer place, they have welded it back up and mechanic has put back in, seems to be drivin sweet now, thank god....
Now onto next issue!
No Problem, welded and fabricated it back up, i hope it does help others as Dealer's are charging approx £250 for that part.
No.1 was one of the sliding doors was not working electronically, but i opened up the track at the bottom and it was a wire split so have soldered that backup and that is ok now.
No.2 the power folding mirrors fold in, but when they fold back out, one of them folds all the way back rather than where it is suppose to stop, ANY IDEAS?
No.3 The alloys are badly corroded, and advice on where to get them done from, as i think they will need shot blasting.
Thats it for now i think....
Was a good one. I am now being sold. Gave up sales last week, disguising after sales week. No idea where I will be next month. I should have taken the job at technical when it was offered.
Thank you anyway.
Thank you anyway.
