Clutch problem
Hi I have a 2.5td voyager w reg the past year it's had problems
Going into 1 & 2 gears the other day it stopped going into Gear clutch pedal has gone in no movement a friend had A quick look showed me the slave cylinder the plastic bit at the Front has snapped still starts but don't go into gear only if you switch Engine off it will drive in 1st gear only would I only need a new slave Cylinder only many thanks. |
