A/cond Compressor
Hi all,
I need an advise on my Chryler Grnd Voyger,3.3l,V6, yr 2000. I've replaced a brand new compressor sometime in Sept 2011. Last weekend,while driving with d A/cond "ON" suddenly I a squeking like sound suddenly appear thru d engine. When I accelerate again,d sound came up again. I then tried to "OFF " d a/cond n d sound dissapear n continue driving. When i on d a/c again,d sound appeared again. I was told by an a/c mechanic that it cud due to d FAN,which might be faulty cuz it not functioning properly according to d right speed. Pls confirm whether tis is true? If its true n d fan need to b replace,shud d compressor b change as well,tqvm. |
If the fans are not sufficient, the high side pressure will go above a certain threshold and the PCM will not engage the compressor. Likely the compressor took a dump again.
This time make sure u have the right amount of oil in the compressor and system itself
Thanks yiu guys,so that sound that i heard when I step on d accelerator is confirmed to be a sound of a KAPUT compressor right.
That shows now I got to replace both d Compressor n d A/C Fan right! There goes d damage...... |
