coolant leak 2002 grand voyager crd 2.5
i have a coolant loss i have replaced the radiator as i found this had been leaking ,i replaced this just over a week ago and still it seems to be losing water
there are no signs of any water traces under the car i have looked everywhere anyone had any similar issues doesnt pressureise the water system and it it not over heating |
Im having the same problem with my 2.8crd.
I have to keep topping up the coolant, but there are no obvisouly signs of where its going. Oil looks fine, no water under car...... |
I believe voyager_dan's problem was a porus cylinder head.
If you are loosing coolant with no obvious leak, then you have to suspect the head gasket or cylinder head. What mileage has it done? |
Its done 56,000 miles. (54 plate)
I will have to investigate.... |
I'd say 56,000 miles is too low to be suffering a porus cylinder head.
I'd have thought a head gasket failure would be equally unlikely in a voyager with that mileage...........although not impossible. (is the mileage definately genuine?) |
Hi ther I have an an '02 3.3l Voyager LHD.
I'm losing water whilst driving, steam is rising from the engine bay the temp is fine but am constantly having to top it up booked in garage for tuesday but was hoping for a quick and easy solution from the forum ! P.S.car in garage for new rad fittlng,261€ about about £215! |
| All times are GMT -5. The time now is 06:35 AM. |
