Crazy Electrical Issues
Hey guys, I just bought a 2014 T&C with 23,000 miles on it. The van is in great shape, clearly well cared for.
We started noticing some weird electrical issues almost immediately - wipers turning on, AC cutting out for a second, small stuff - then the whole dash went nuts with all the gauges and lights, wipers and AC cutting in and out at once. From what I've read, this sounds very much like a bad TIPM. Is there a way to be sure? Any advice would be greatly appreciated. |
Try disconnecting the battery for a few minutes to reset the computer and see if that helps.
Let us know if it works for you. |
Originally Posted by CinSC
(Post 110362)
We started noticing some weird electrical issues almost immediately - wipers turning on, AC cutting out for a second, small stuff - then the whole dash went nuts with all the gauges and lights, wipers and AC cutting in and out at once. From what I've read, this sounds very much like a bad TIPM. Is there a way to be sure? Any advice would be greatly appreciated. We understand why this may be concerning. We suggest having your dealer inspect this concern if you have not done so already. We are also available via private message if you would like any additional assistance during that process. Lydia Chrysler Social Care Specialist |
Originally Posted by BiliTheAxe
(Post 110365)
Let us know if it works for you. Anyway, the electrical guru at the Chrysler dealer is narrowing the problem down to the radio - maybe. :) |
The problem may be due to ac relay in the fuse box under cover at the driver side
(Post 110389)
Thanks. I was concerned after reading some of the issues resulting from bad TIPMs, so I disconnected the batter overnight. The problem recurred on the way to the dealer. Sustained right turns trigger it. ??
Originally Posted by Maurizio
(Post 110458)
I disconnected radio to me still has problems. Have you solved with your car?
wow i'm glad for you i'm looking for this cable for a year. This chrysler is full of cables and control units.
Originally Posted by flyingpostman
(Post 110462)
I had a "No Bus" electrical problem that led the dealer to replace the radio, which didn't fix the error. If you are getting a ground fault somewhere it will take a dozen modules offline and record all those in the computer and there is no way of knowing what is causing the issue. The dealer will only tell you that they can narrow it down while it is doing the error, which can be impossible if you don't know what is causing it. In my case, it only happened when my wife was driving the van. Took me weeks and weeks to figure out what was causing it. My wife is very short and drives with the seat far forward. Over the course of 2.5 years the unprotected wiring harness under the seat was wearing against the seat bracket, which only happened in her seat position, not mine. I taped up the wires and the problem went away. Long story short, it could be any wire, anywhere causing an issue. You have to use your sleuthing skills to figure it out. I thought all hope was lost because the dealer couldn't find it and it went out of warranty during that time.
The "seat forward" issue you had is interesting. My van schitzes out when we make a sustained right turn - like on an on ramp. Whatever the case, I'm not sure we want to keep this thing. How often are these weird issues sorted out for good? |
(Post 110518)
Well, the dealer replaced the radio and some of the problems are resolved. So the hunt continues.
