CV-joint dis-assembly
Hi
I've got a 2008 Town Country with a bad wheel hub front left that needs to be replaced, but the CV-joint axle is really stuck in the hub, removing the drive-shaft from the CV-joint would make things easier pressing the CV-joint out of the hub. Is it possible to remove the drive shaft from the outer CV joint, with destroying anything? Thanks! |
With the axle nut still on but loosen'd to protect the threads, did you try a sharp "rap" with a large hammer after spraying a good (PB Blaster) penetrating oil to the spline area?
