Diagram of a Left front sway bar on T@C
Old Jan 29, 2008 | 08:58 PM
3.3lxbluevan's Avatar
Default Diagram of a Left front sway bar on T@C
I want to see a diagram of a sway bar (LEFT FRONT Driver Side)on the 2001 T@C and a sway bar link end. I want to either try to change the bushings out or tighten It up again.
Old Jan 30, 2008 | 09:54 AM
moe's Avatar
moe
Default RE: Diagram of a Left front sway bar on T@C
1 - STEERING GEAR
2 - STABILIZER BAR
3 - RAISED BEAD
4 - FRONT CRADLE CROSSMEMBER
5 - RETAINERSthis what you looking for? moe
Old Jan 30, 2008 | 09:56 AM
moe's Avatar
moe
oh much better!
1 - TOWER
2 - CROSSMEMBER TAPPING PLATES
3 - LEFT STRUT ASSEMBLY
4 - LEFT STEERING KNUCKLE (WITH HUB AND BEARING)
5 - STABILIZER BAR LINK
6 - STABILIZER BAR
7 - LEFT LOWER CONTROL ARM
8 - CRADLE/CROSSMEMBER
9 - CRADLE/CROSSMEMBER REINFORCEMENT
10 - BALL JOINT
11 - ISOLATOR BUSHING
12 - STEERING GEAR TIE ROD
13 - RIGHT STEERING KNUCKLE
14 - RIGHT HUB AND BEARING
15 - RIGHT STRUT ASSEMBLY
Old Jan 30, 2008 | 07:25 PM
YES, thanks man, I just got the brake washers on and I had a serious brake leak and that's tooken care of now. I went to the dealer to ask for the stabilizar bar links because my car Is making clunking noises when I am going over bumps and speed bumps. I can turn slightly right and left I will hear a clunk noise so the cost of the bar Is $64.00 each. THAT'S ALOT OF MONEY.
Old Jan 30, 2008 | 08:10 PM
The retainers Is what I was looking for.
99TandCMN
Apr 16, 2018 05:25 PM
Erbie78
Mar 16, 2011 11:24 PM
dcotter0579
Sep 28, 2010 12:20 PM
jgorczynski
Jun 8, 2010 10:08 AM
jennellnjeff
Oct 26, 2007 01:51 PM
