Difficulty starting in cold weather. Voyager 2.8 CRD
Hi
I am new to this, hopefully I am placing my post in the correct area (I have now!) Ok, here is my issue, first, details of the car - 2006 Chrysler Voyager 2.8 CRD LX Auto Problem: When the weather was very cold (-14 C here in Hungary) the car struggled to start with masses of black smoke out of the exhaust, now that the weather is generally 28 - 30 deg it starts first time every time Diagnostics: I checked the IPM Unit and found that F17 (20A) was O/C, I replaced this and immediately blew once I started the engine, I managed to find a part manual on the web and discovered that the fuse feeds the fuel heater relay (all beginning to make sense). I removed the fuel heater relay, replaced the fuse and sure enough this time the fuse did not blow. I measured the resistance between relay pin 30 and deck which gave me a reading of 0.2 ohms, hence the blowing of the fuse and the problem being either the fuel heater unit or the wiring loom. (although on one site I looked at it was mentioned that it could be the crank case Ventilation heater, does my model have one?) Has anyone else experienced this same issue and did it turn out to be what I suspect, any help would be much appreciated. Basic question but where is the fuel filter/Water separator/fuel heater unit on my model as I have read conflicting reports on this and if it does turn out to be the fuel heater unit does anyone have the part number for it and where can I get one apart from Chrysler which my understanding is that they are not very helpful. Lastly, how difficult is it to replace this unit within the fuel filter/water separator, I have worked on older cars in my youth but as we all know modern cars are somewhat mind blowing! Any input would be much appreciated Eddy |
When were the glow plugs last changed? Glow plugs main function is to avoid the cold start condition you described by preheating the combustion chamber when you put ignition on before you turn the engine to start. Will only work when outside temperature is somewhere like 4 Celsius or lower.
Thanks for that, That was my first thought until I checked the fuses and found that I have a fuse blowing supplying the fuel heater relay which again only operates below 8 deg C ambient temp?
What would be the symptoms of the Fuel heater not working? |
Leedsman on the issue.
Thanks, I will await your reply
Regards |
