Drivers electric seat won't work
My 2006 Grand Voyager's seat has stopped working. Where is the fuse ? Is there another possibility ? I have checked leads etc., buit can't see anything loose.
Maybe this will help. It's from the 2001-2007 Dodge Caravan Service Repair Manual:
DIAGNOSIS AND TESTING POWER SEAT SYSTEM Following are tests that will help to diagnose the hard wired components and circuits of the power seat system. However, if the vehicle is also equipped with the optional memory system, these tests may not prove conclusive in the diagnosis of the driver side power seat. In order to obtain conclusive testing of the driver side power seat with the memory system option, the Programmable Communications Interface (PCI) data bus network and all of the electronic modules that provide inputs to, or receive outputs from the memory system components must be checked, (Refer to 8 - ELECTRICAL/POWER SEATS - DIAGNOSIS AND TESTING). WARNING: SOME VEHICLES ARE EQUIPPED WITH SEATBACK MOUNTED AIRBAGS. BEFORE ATTEMPTING TO DIAGNOSE OR SERVICE ANY SEAT OR POWER SEAT SYSTEM COMPONENT YOU MUST FIRST DISCONNECT AND ISOLATE THE BATTERY NEGATIVE CABLE. THEN WAIT TWO MINUTES FOR THE SYSTEM CAPACITOR TO DISCHARGE BEFORE FURTHER SYSTEM SERVICE. THIS IS THE ONLY SURE WAY TO DISABLE THE AIRBAG SYSTEM. FAILURE TO DO SO COULD RESULT IN ACCIDENTAL AIRBAG DEPLOYMENT AND POSSIBLE PERSONAL INJURY. (1) If either power seat is completely inoperable, check the power seat circuit breaker, located under the trailing edge of the driver side power seat. If the power seat circuit breaker is OK, continue to the next step. (2) Check for proper battery and ground connections at the power seat switch and/or memory seat module. Repair any wiring as necessary. (3) Check the power seat system wire harness connections and pins to ensure proper circuit continuity and ground paths. |
