ECU connector pins id-
2002 TC 3.3L no EGR, no flex : need the ECU connectors pins ID. Need the the wire to injector #5 specifically.
Getting constant( not intermittent) .24mv at the both sides of the connector to the main wiring harness , using digital meter to measure voltage |
PCM connector C1 contact #15 brown/orange tracer to pin #2 at injector #5
Thanks a lot.
Do you have the connector pin layout? Is that the top connector to the ECU?Which is the location of number 1 pin in the conn.? |
Wish I could tell you but I was just looking at a wire diagram. That info isn't given. A pretty good bet pin #1 is at upper left but then we are talking about Chrysler so logic may not apply. All the injector wires are on consecutive contacts in the same C1 connector. Send me a private message with an email address and I'll send you the wire diagrams.You can then match up the wire color IDs and identify the connector and pinpoint #5 that way. Kinda through the back door.
thanks alot. I just finished removing the cover of the wiring harness, looking for a short. I did not find one, so I think I have an ECU problem.....sh.....
this Chrysler are sh... |
