EGR
My '97 T&C's check engine light recently came on, and the trouble code was (I didn't write down the number) EGR low emission. I replaced the EGR valve, and still have the same problem. Are there any sensors that work with the egr valve? Any help would be appreciated.
RE: EGR
Mileage?
Symptoms, anything like that would be helpful.... http://www.partsamerica.com/product_..._full_0552.jpg [ol][*]Remove EGR tube attaching bolts from intake and exhaust manifolds.[*]Clean intake and exhaust manifold gasket surfaces. Discard old gasket.[*]Check for signs of leakage or cracked surfaces on either manifolds or tube. Repair or replace as necessary[/ol] ================================================== ====== Check your lines, EGR Solenoid connections, and wiring..... |
