egr valve
is the egr valve easy to change? any ideas on where it is located? thanks. the code was 0401 EGR Valve flow insufficient.
RE: egr valve
what year and engine?
RE: egr valve
sorry, 2001 Chrysler T&C with the 3.8l
RE: egr valve
right in front of the engine 2 13 or 10 mm bolts and 2 8mm bolts holding the egr tube.
RE: egr valve
looks fairly easy, thanks for the help
RE: egr valve
Make sure the problem is not just carbonclogged EGR ports in the throttle body before you replace the EGR valve
RE: egr valve
thanks, I was thinking the same thing, I am planning on getting the gaskets this next weekend to check it out
