-   Chrysler Voyager & Town & Country (https://www.chryslerforum.com/forum/chrysler-voyager-town-country-21/)
-   -   Error Codes (P1130, P0520, P1685, P0100, P0641, P0190) (https://www.chryslerforum.com/forum/chrysler-voyager-town-country-21/error-codes-p1130-p0520-p1685-p0100-p0641-p0190-26858/)
justplaincornel Dec 11, 2016 10:21 AM
Hi There,
I have and UK registered, 05 2.8 CRD car and I never checked the Error Codes before today.
The car drives fine, good MPG, starts every time.
I just checked the codes after reading in here the key ( turn on- turn off 3 times method)
To my surprise, there were lots of codes displayed (P1130, P0520, P1685, P0100, P0641, P0190).
My car seem OK and I cannot see any problems.
Can they be historical codes (problems that previous owners would have sorted out and never erased the codes)?
also, the order in which they were displayed : is that the list that they ware logged?
Also some codes flashed on the dashboard for 10 times while others only once or twice. Does it matter how many times each code was displayed?
Can it be a faulty ECU that randomly displays codes?
I did look on the forum and there are no answers I can get so please if you can answer any of the points about I will appreciate your help
I wish I did not check the Error Codes (at least without checking I had peace of mind)
QinteQ Dec 11, 2016 02:44 PM
P0's --- are all GENERIC TROUBLE CODES
P1's --- are all MANUFACTURER CONTROLLED CODES
P00's --- are all GENERIC CODES
10 flashes means 10 separate occurrence of that fault whereas for example 4 means 4, and yes they can be historical. If your having no problems be a happy man, and congratulations.
Vonhofinvule Dec 14, 2016 11:58 AM
Personally I would clear them, run for a few days and see if any re-occur!
justplaincornel Dec 14, 2016 12:05 PM
Thank you very much
I tried to clear them; I purchased a tool to read errors and clear them, but the tool says there are no errors (the tool works as it connects and can communicate with engine because returns some information from the ECU)
So one dash, codes are displayed (when key is on-off tree times), there is no problem with the car, the ODB reader returns no error codes
I am still puzzled by why they are there, but since no problems I am starting to ignore them
Regards
QinteQ Dec 14, 2016 04:23 PM
Originally Posted by justplaincornel (Post 98461)
Thank you very much
Its likely that 90% of all the codes can not be read by a cheepo reader, usually the most it will do is return [ODB] emissions codes. A cheepo reader certainly won't even see the other codes. There's a mile difference between a reader and a scanner and a diagnostic scanner. I have x2 full spec diagnostic scanners and one won't even see my 2.8 CRD engine at all [my expensive mistake], the reason I say this is be careful, very careful what you buy and any advice you are given by so called experts.
The 'key-dance' will as you know return your basic codes, as you have no problems, you have no live errors, stop being a 'werrit' ! Best of luck.
