Fault code p1776
Help please, just ran a dio test on the voyager and showing the above code, had a look on line but really unsure what it means? Can some one help please?
First thing is to check fluid condition and level, then the fault finding procedure can be found here
http://oskin.ru/pub/chrysler-dodge/m...ansmission.pdf Regards Richard |
P1776 - Solenoid Switch Valve Latched in LR Position (this is a transmission issue which may involve replacing the valve body and solenoid pack; on some models there is a TSB on this problem so be firm with your dealer / Chrysler).
Just had the same thing happen i managed to delete the code and get out of limp mode to get home. Iam going to have a good look in the light and hope its something simple i will update or cry tomorrow.
the solenoid pack is more then likely need to be changed.
yes.. I had the same issue with the fault code.... mine was under drive solenoid problem. needed a new auto transmission solenoid pack on... £800 but it was still under warranty thank god lol
Does any one know where to get one and is it a diy job or off to the garage
best off ordering one from the US
Chrysler Solenoid Pack: Automatic Transmission Parts | eBay Regards Ricahrd |
