Front Blower not Working
I have a 2006 Town and Country with about 60k on it. All of a sudden the front blower has stopped working. The rear works just fine. I have checked the fuse and all seems ok there. How do i go about troubleshooting this problem?
Thanks |
RE: Front Blower not Working
does it work on any speed at all or is it totally dead? THere is a relay also for the front blower that you should check out. If that is ok then the only things left are the motor itself, the control head or the power module/resistor (behind the glove box. If you aren't getting high speed than the resistor is not your problem
Johnny,
The blower is totally dead, no speed works. What next? |
all correct unless u have an auto temp control ac head and then vary possible the resistor power module is at fault
so can you tell me what to look for and where do i look for it?
same place at the other resistor behind the glove box.
