Front End Shimmy
05 T&C (Touring)with 42K miles
On various roads, when you let go of the steering wheel, it vibrates on its own back and forth (more than it should). I had the sway bar links replaced under warranty due to front end noise, but I was wondering if anyone has an opinion on this issue. Do you think tie rod ends or perhaps sway bar bushings?My wife drives the van and is complaining to me about this. IMHO, I believe that the van just has a vague/loose front end inherent in the design, but I'm open to other opinions. Thanks for your input... Bill |
RE: Front End Shimmy
Check you tires, I think you have a bad one. If you had a flat or one that requires air that would be a good start point.
