Fuel filter system
Hey
I have a Grand voyanger 2.8 CRD Stow `n go 2006 model and I would need a new or used fuel filter, the whole bracket system? Has anyone else had to get one? I live in Finland, so it would be good if some could be found here in Europe. Mika |
Fuel Filter
Replaced mine around 24 months ago, not cheap and had to buy from ebay..
Fuel filter, primer unit - around £240.00 - ouch. Do not buy second hand unless within return distance, the connector to the aux heater tends to overheat and cause leakage (From the recall notice) ->REPAIR PROCEDURE: 1. Replace the fuel filter/water separator assembly per part table above. Follow the detailed service procedures available in DealerCONNECT/TechCONNECT, Refer To Group 14 - Fuel Systems> Fuel Delivery - Diesel > Separator and Filter Fuel and Water Removal and Installation Procedures. 2. Replace the fuel heater connector, terminals and wiring with kit number 68043086AA. Follow the detailed service procedures available in DealerCONNECT/TechCONNECT, Refer To connector and wiring repair information available in the Wiring Tab under 8W - 01 Wiring Diagram information > Connector, Terminal and Wire removal and installation procedures. https://cimg9.ibsrv.net/gimg/www.chr...36b7ce95ab.png |
