grand voyager 1993 not water temperature
my voyager not indicate the temperature of water. if the fan of cooler working, i don't now. this car have 2.5 turbodiesel engine. any idea? thanks
regards, george |
Check the wire going to the temp sensor. It is on the right hand side of the engine on the last head. (If yours is the 1996-2000 2.5TD it has 4 small cylinder heads)
thanks for your answer. i will check. my voyager is 1993
The 1993 used a variation of the same engine. It has been around a very long time and in fact was originally made for marine use.
I already checked the temperature sensor and is 200-600 ohms, so it's okay. I guess the problem is in dashbord. and maybe a possible interrupted cable.
regards, geo |
dashboard was ok. i found a wire interrupted near battery support.
@glowplug: you had right, was a wire. thx for help |
| All times are GMT -5. The time now is 05:17 AM. |
