Grand Voyager 2.8 CRD diesel consumption super High
Hi
Looking for any tips and help. Error code p1130 On full tank 70L can do only 220mpg fuel presure valve replaced,fuel rail sensor replaced no black smoke coming when acelerating only little white when starting from cold. Thank you |
When I read this I instantly thought of Lambda Sensor, must have been a past fault I was reading about with the result. Don't think it was a Chrysler though.
Thank you for your replay.I will look in to this one for sure .maybe I'll replace quckly it dosnt cost that much.
Wait to see if you get an opinion from one of the other guys on here.
Will do :)
The consumption £ is killing me
It's to do with the Air Fuel mixture where your running rich and Lambda has picked it up as code P1130. I take it your Air filter is not clogged. Then there's the MAF sensor but your not having power loss issues.
No issues with power.The air filter was replaced 1 month a go
Ok thx will check this out .
| All times are GMT -5. The time now is 02:59 AM. |
