Grand voyager 2.8crd Cambelt
Hi All
I wonder if anyone can advise ? Just returned home from the garage after having the cambelt changed on my 2005 Grand voyager 2.8 crd, 28k miles, The car seamed to drive o.k. but when I switched the engine off, it shuddered to a stop. This it has not done before, normally you switch off and the engine stopped smoothly with no judder. I phoned the garage straight away ,they spoke to the mechanic who did the job, he says the timimg is set right but they have agreed to look at it again tomorrow. Any adivise would be much appreiciated before i take it back. Regards Al. |
Thanks for the link booke23, but the panic is over,took the car back to be checked and they found that the front engine mounting is quite weak allowing the engine to rock back and forth when you switch off, having it changed on wednesday.
I forgot to mention in my earlier post , that when i had the cambelt changed i also had a new Cat. fitted as tha Cat. was making a terrible rattle on idle, this is why i never noticed the engine rocking on switch off. feel a bit of a pratt really. Thanks again for your reply regards Al. |
cat must be warranty is it not if you are under 50k
