GV. handbrake tip.
Old Jun 18, 2015 | 04:57 AM
Leedsman's Avatar
Default GV. handbrake tip.
If you don't use your GV handbrake much with it being an automatic vehicle, the auto-adjust clutch can lose grip on the square section spring. So when you put on the handbrake it could go all the way to the top.
It is only necessary to put on the handbrake two or three times to take up the slack, so using fewer "clicks". The first pull starts the auto-adjust system.
Leedsman.
Old Jun 18, 2015 | 06:21 AM
darkcild101's Avatar
Leedsman.
Mine is a manual and the handbrake travels all the way to the top before it grips. I take it this auto adjust in only on autos I wish there was a way of repair that didnt involve going under the car
Old Jun 18, 2015 | 06:37 AM
Leedsman's Avatar
As far as I know, all the GVs have the same autoadjust handbrake. and it adjusts for slack in the cable. But I can't see it adjusting the brake shoes inside the drums. Those are the old-fashioned type where you put a screwdriver through a slot in the brake back plate and work it up or down to put the shoes hard "on", then back it off until the drum is just free. Chrysler's auto-just handbrake system has been around a long time.
If you've not serviced the handbrake system in a long while, carry out an inspection, clean out and adjust the drum/shoe assy. Or of course pay a mechanic to do it.
There is lots of info. how to do a service of handbrake shoes on here. Lots.
Leedsman.
Old Jun 18, 2015 | 07:31 AM
- engine running
- footbrake [servo] applied hard
- grab handbrake, button permanently in, 6 to 10 hard pulls one after the other
- let go of handbrake in the off position
- release foot from the footbrake
- switch engine off, make coffee, read newspaper, handbrake is auto-adjusted
Old Jun 18, 2015 | 07:44 AM
Originally Posted by QinteQ
- engine running
Thanks Leedsman and QinteQ
Old Jun 22, 2015 | 05:28 AM
- engine running
I did as you advised and all is well now. Thank you
Old Jun 22, 2015 | 08:34 AM
- you are welcome my friend, that's why we are all here
- we are always better as a 'collective'
- 200 brains are always better than one
silentdub
Apr 27, 2015 01:08 PM
ToddShroats
Mar 23, 2012 09:18 PM
glowplug
May 5, 2010 02:31 AM
15951a\
Mar 15, 2009 09:43 AM
swittie
Apr 7, 2008 07:05 PM
