Heater Control
Will a heater control out of a 97-98 Town and Country work in a 99?
Thanks Candice |
Originally Posted by 4gmommy
(Post 31180)
Thanks Candice |
No no nothing like that, the driver's side temp lever has been broken off deep inside the unit since we bought it 2 yrs ago, and it makes driving chilly. Also the rear deforst button is toast and the rear washer as well.
All fuses check out, so I got a heater control the other day. looked identical, but plug on back was black instead of white(stock is white). The rear defroster began working as well as both sides of temp control, but the rear wiper stopped working. Turns out the replacement I sourced was from a caravan not a T&C, and electronically they aren't 100% interchangeable....so I am trying to find out what yr's I can source this part from to broaden the chances of my finding a good used part. |
(Post 31186)
All fuses check out, so I got a heater control the other day. looked identical, but plug on back was black instead of white(stock is white). The rear defroster began working as well as both sides of temp control, but the rear wiper stopped working. Turns out the replacement I sourced was from a caravan not a T&C, and electronically they aren't 100% interchangeable....so I am trying to find out what yr's I can source this part from to broaden the chances of my finding a good used part. ok checked my interchange 1999-2000 only. I have a 2000 t&c heater control panel with rear heat controls. sell it to you CHEAP if your in the US. |
Hello
Originally Posted by 22chrysler
(Post 31189)
