Which heater core should I order???
Hi,
I'm sure this is a quick and easy one for the experienced here! I have a 2002 Chrysler Voyager, 3.3l Flex Fuel 6 cyl. I need to replace the heater core under the dash board. Which one is it, the front or rear heater core? Best, Ben |
I must have not had enough coffee today are u asking which heater core u need to replace because what why? There are 2 yes under the dash and on in the back. sooooo what are u asking.
Apparently I'm not sure what I'm asking....
We live in Belize, Central America. About two years ago they simply took out one of the heater cores and shut off the fluids that circulate to the cores. I'm not sure which one as I wasn't sure that there was more than one.
I will ask the mechanic that did the work WHERE exactly the core was that he removed that was leaking. We couldn't get another one at the time so we simply opted to get rid of it for now. I do remember that he said that the lines of the heater core can rub with the lines of the AC lines under the dash and cause a leak. That was the cause of our problems. I'll get more information and get back to you! Thanks, Ben |
