how to change light behind gas gage 02 voyger cant seem to locate
have taken dash almost apart cant find bulb:eek:
RE: how to change light behind gas gage 02 voyger cant seem to locate
i dont think u can replace it do u have the cluster out of the van and the back apart??
no i havent figured how to get it out havent done much mechanic work for past 20 years only hot rod work now all of the light work except the gas went dim cant see at night, was hoping i might save garage fee and replace bulb if possible
welll here ya go then dont worry about the battery though
REMOVAL WITH ELECTRONIC TRANSMISSION RANGE INDICATOR [ol][*]Disconnect and isolate the battery negative cable.[*]Remove Over Steering Column Bezel by lifting it straight up with a firm pull.[*]Remove the four cluster bezel attaching screws.[*]Tilt the steering column in the full down position.[*]Pull rearward on the cluster bezel and remove.[*]Remove the four screws holding instrument cluster to instrument panel.[*]Rotate top of cluster outward.[*]Disconnect the cluster harness connector.[*]Remove instrument cluster from instrument panel.[/ol] |
| All times are GMT -5. The time now is 11:41 PM. |
