How hard is it to replace condenser?
I have 2005 T&C Limited and driver side is blowing warm as passenger side is cold. I do believe it is the condenser leak. Is this something DIY can be done?
Why would you think it's a condenser leak if one side is till blowing cold? You have a problem with your blend doors or the actuators...maybe even the control head. A dash pull is not a DIY job usually.
I thought it was blowing one side cold, but it is warm both side. I just replaced the rear evaporator and need to pull the condenser to replace. It seems the freon has escaped since it is blowing warm and the compressor is not kicking in due to low or no pressure.
look at the lower left hand side of the condenser if it is wet its is leaking
Condenser
(Post 42542)
how to remove fascia grill
Originally Posted by Kaysvan
(Post 42529)
I believe the answer is here: 2002 Chrysler Town And Country Condenser Replacement Has anybody done this recentlty? In particular: The text does not say that the front fascia grill must be detached from the bumper. Is this correct or merely assumed self-evident? If the fascia grill needs to be removed, how can I get it apart from the bumper? |
Originally Posted by Jacob25crd
(Post 51899)
I have exactly the same question.
I believe the answer is here: 2002 Chrysler Town And Country Condenser Replacement Has anybody done this recentlty? In particular: The text does not say that the front fascia grill must be detached from the bumper. Is this correct or merely assumed self-evident? If the fascia grill needs to be removed, how can I get it apart from the bumper? Fascia and bumper are the same piece. Some push pins along the bottom and a screw or two behind the inner fender shield that attch it to the fender. |
Ok thanks this is helpful.
I thought "fascia" meant only the grillle between the headllamps. I had been tempted to remove the bumper but did not dare at the time. I will now have a new go at it. Thanks. |
98 Chrysler Concorde 3.2 engine AC condenser replacement instructions.
Can anyone help me |
98 Concorde 3.2 engine AC condenser replacing
AC condenses reportedly leaking and a vacuum cannot be pulled.
I have new condenser but had no instructions on the installation procedure. Can anyone help me? |
| All times are GMT -5. The time now is 06:24 AM. |
